Smartbook wm8505 help
Discussion in 'WonderMedia WM8505 Tablets' started by nsantos, Jan 4, 2011.
  1. nsantos
    nsantos Member
    nsantos
    To install android on my smartbook wm8505 did the procedures, put the script folder in the SD, he showed that three steps were completed successfully. But it was a long time on this screen and not asked to disconnect. After some time so I hung up, took the SD, I was starting, but nothing. The LED lights up but the screen remains dark, nor the message "loading the image" does not enjoy most. What happened?? what can I do?
    help
    tanks
  2. probbiethe1
    Gilbert, Arizona
    what procedure did you do?
  3. nsantos
    nsantos Member
    nsantos
    appeared these three steps, but with android and then blocked
  4. feketedini
    feketedini Member
    Hello! I have a mini notebook.
    Processor Type: VIA ARM 32bit CPU
    Processor Speed: 266 MHz
    Processzor Modell: VIA-ARM 920
    Screen Size: 7 inches, 800x480
    RAM: DRAM
    RAM: 128 MB
    Primary Drive: NAND Fast Flash
    Hard Drive Capacity: 2GB
    What kind of android version need I?
arm wm8505
