Soft Buttons - Pro or Con?
Discussion in 'Coby Generation 2' started by racemi, Apr 26, 2011.
  1. racemi
    racemi Member
    CT
    Coby
    I don't know how anyone else feels about the soft buttons on the 7024, but I find them to be way too sensitive, and somewhat redundant. The only soft buttons I regularly use is the "M" menu button and the "back" button. The rest I can do without since I can get to a search engine or browser from the touch screen. Of course the "home" key being a real key, is fine where it is. I keep hitting the bottom soft key by accident when holding the tablet.
    Has anyone found a way to turn the soft buttons off? Maybe there is a way to change the sensitivity of the buttons somewhere in the firmware?
    I realize that this is a small inconvience, and I will learn to hold the tablet diffetently so I don't hit the button(s), but it would be real nice if they could be controlled somehow.
  2. PartsMan
    PartsMan Member
    Oklahoma
    Coby Kyros 7024
    I have gotten used to them and use them quit a bit now.
    My four year old hates them. Keeps hitting search in the middle of his game.
    I do catch myself trying to push them wit the stylus a lot though.
    A screen you almost need a stylus for and buttons you can't use one on. :(
  3. Jory76
    Jory76 Member
    USA
    Coby Kyros 7024
    I am also looking for a solution to this. My four year old also hits them a lot.
  4. dave52355
    dave52355 Member
    NULL
    The on screen launcher buttons can be changed to any app. Somewhere in the belly of this beast has got to be a setting that can change the sensitivity of the buttons. My biggest concern would be that the option may only be on/off. I've been looking into the setup and init files but have not had much luck yet.
  5. strifesephiroth
    strifesephiroth Member
    Dominican Republic
    Kyros MID7048
    I hope Coby launch an update to solve this. I think it's the only thing hate from this tablet.
    Sent from my MID7024 using Android Tablet Forum
  6. Jory76
    Jory76 Member
    USA
    Coby Kyros 7024
    I figured out how to disable the soft buttons. You need to use ADB to pull /system/usr/keylayout/qwerty.kl , open it in wordpad and comment out ( put a #) in front of the key you want to disable.
    So search would look like this normally:
    key 217 SEARCH WAKE_DROPPED
    You need to make it look like this:
    #key 217 SEARCH WAKE_DROPPED
    To disable the browser key, you just do the same to key 48.
    After you have edited and saved your qwerty.kl file you need to use ADB to push it back to your tablet. Power your tablet down, turn it back on you are done.
    TADA! No more hitting the badly placed search or browser buttons on accident!
  7. nba1341
    nba1341 Senior Member
    California
    Coby Kyros MID7022
    ^You can also use this to remap buttons to another function
am i alone or does anyone else hate the nexus soft key os
