software problems pleasse Help
Neetje
i had many problems with the zenithink but till now they are all solved.
now i have the next problem:
i turn on my pad and it starts with zenepad and then switch to the green android figure you see a white dash flickering this dash stops and then nothing happens.
so i think that it get stuck in the booting is there any way to solve this or maybe is there a way to put new android on the machine
Thanx René
Neetje
i did try that many times but did not help i even opend the tablet to take it of the batery and after that did a other reset still nothing.
Sandakelum
Hi, If you can tell me the model of you tab, i may help you, what is your tablet model? Zenithink model No?
