Solution for SDCARD mount point [Watery Kyros]
Discussion in 'Coby Generation 1 Technical' started by zhyon, Apr 27, 2011.
  1. zhyon
    zhyon Member
    Gome Flytouch / Coby Kyros
    I had some trouble with music, photos and videos applications, since I installed Watery Kyros ROM, because they could not see music, pictures and videos folders on the SD
    card but only on NAND directory. Based in the directory tree of my S Galaxy, which places SD directory as a subdir from /NAND, I made ​​the following changes:
    in /etc/vold.conf, search for "volume_sdcard {" and change "mount_point /sdcard" to
    "mount_point /nand/sdcard".
    in /init.rc, search for "mkdir /sdcard 0000 system system" cut this line and past as a new line after "mkdir /nand 0000 system system", changing to "mkdir /nand/sdcard 0000 system system"
    Rebooted system.
    Now sdcard mounts atr /nand/sdcard, I can access using Root Explorer or And Explorer, but system continues "Checking for errors"... any one could help me with it?
  2. wreichard
    wreichard Member
    Earth
    Kyros 7015
    zhyon--did you ever find an answer to this? thanks
  3. bsinclair
    bsinclair Member
    Kyros
    Would love to find the same answer, does this works or, what is missing?
