[SOLVED] Authentication Problem With Home Network
Discussion in 'Android Tablet Q&A' started by gordc, Sep 13, 2015.
  1. gordc
    gordc Junior Member
    Using a tablet for the first time (Proscan 10 inch running Android 4.4). The setup for my network appears normal; the correct ISP and WPA2 code entered. The screen shows "saved and secure" but any attempt to connect to the web shows the message "authentication problem".. The signal strength is excellent.
    Do I have to have a Google account to fix this?
    gordc
  2. leeshor
    leeshor Senior Member
    Norcross, GA
    Samsung Galaxy Tab S 10.5
    Welcome to the forum
    When it says saved, that's when you have a problem. It should say connected. You may want to start be rebooting your router, then tell that connection to "forget", restart the tablet and try again. I have a link below with additional suggestions.
  3. gordc
    gordc Junior Member
  4. gordc
    gordc Junior Member
    What happened was that the WPA security code was "corrupted" by the keyboard switching to lower case. So, problem solved.
    thanks,
    gordc
  5. leeshor
    Norcross, GA
    Good deal.
home network authentication problem
