[Solved] tablet not recognising usb storage devices - camera & android phone
Discussion in 'Android Tablet Q&A' started by thermalnermal, Oct 8, 2012.
  1. thermalnermal
    thermalnermal Member
    uk
    a1cs fusion 5
    hi
    i can't seem to find an answer to my specific problem anywhere.
    i am trying to get my a1cs fusion 5 running 4.0 to recognise external usb storage devices - htc desire android phone and nikon coolpix s8200. i get an error message "sd card is damaged". they are not damaged my computer can read them . my computer can also read the tablet via usb.
    is it just me? is there something simple i can do to fix this? or is the tablet faulty?
    tablet has 2 micro usb ports - one is usbhost.
    very grateful for any help available
  2. leeshor
    leeshor Senior Member
    Norcross, GA
    Samsung Galaxy Tab S 10.5
    Welcome to the forum
    If it was me, I would try something a little more standard like a flash drive or an NTFS formatted hard disk to rule out the tablet as being the problem. It could be the file system on both devices that has your tablet confused. If a flash drive doesn't work you could at least try a restart of the tablet but I'm not certain that would help.
  3. thermalnermal
    uk
    a1cs fusion 5
    I tried a standard flash drive. It mounts and reads it no problem. Is there something I can do to make it recognise the other devices. They are not faulty - the computer can see them.
  4. leeshor
    Norcross, GA
    My guess is that the format of the other devices is not being recognized. Android will see NTFS and FAT32 and with some versions exFAT. Your computer may be able to recognize additional formats.
    The only thing I could suggest is reformatting the cards to see if the other devices can still see them but that's a tuff call.
  5. thermalnermal
    uk
    a1cs fusion 5
    Solved!
    In the end I took the sd card out of the camera and mounted it with an external sd card reader. The android could read it with no trouble. Simples!
android tablet not reading usb
android usb storage damaged
camera storage device problems for android phones
cannot readmy usb key android tabley
damaged external usb storage
damaged external usb storage android
damaged usb storage android
damaged usb storage android phone
damaged usb storage android tablet
how to fix damaged usb storage on android tablet
how to fix damaged usb storage on tablet
how to fix usb storage damaged
how to fix usb storage damaged on android tablet
usb device not recognized android tablet
usb storage damaged
usb storage damaged fix android
usb storage is damaged
versus tablet usb storage damaged
what is damage usb storage
why wont my andriod tablit recognise usb memory
