Speed up your flytouch 2 (no rom, no costum firmware, no root)
mdlc
how to speed up your flytouch 2 after the android boot screen for 90%!!!.
Step 1:
Download & install Launcher pro (plus) at the market.
Step 2:
Download & install Home Manager at the market.
Step 3:
Open home manager and select launcher pro (plus) as default.
Step 4:
Kill (don't uninstall) the default home.
Step 5:
Download and install startup cleaner and clean all the apps you don't need.
Step 6:
Tap home (right corner) and select "complete this action with" launcher pro and select as defaul
Optionally steps (ROOT needed) (you can root your flytouch with universal androot)
Step 6:
Make even after reset launcherpro default:
Change in root: wowhome.apk to wowhome.apkz
Change in root: Launcherpro.apk to wowhome.apk
Step 7: Download Bloatfreezer or something similar.
Disable more system apps (Caution be careful!!)
If you have any questions post it!
:D
