stuck in apx mode
Discussion in 'Lenovo IdeaTab A2109 Technical' started by killer2020, Jan 4, 2016.
  1. killer2020
    killer2020 Senior Member
    hello guys after i flashed the cm12.1 i booted and it wont boot i plugged it to pc and its in apx mode so how can i normally boot
  2. PJBrs
    PJBrs Senior Member Developer
    Hi killer2020, the problem is that we need a Secure Boot Key to get from the apx mode to the nvflash mode. We don't have that key and I don't have the knowledge of how to acquire it. The best explanation I saw is at the androidroot.mobi site.
    The androidroot.mobi site also has an explanation of how their tools work on grouper (2012 Nexus 7) and cardhu (tf300, tf700) devices. This includes a few specific steps:
    1. Using fastboot to flash a patched version of a bootloader to the bootloader partition
    2. Rebooting to the patched bootloader to boot a tailor-made boot-image that produces various specific blob files that you can use to get from apx to flash mode.
    The first problem for us is that we do not have an androidroot.mobi-patched version of our bootloader. The second problem is that I don't know whether their tailor-made boot-image would produce specific blob files that work on our device (I checked this boot img; it uses some kind of modified init to produce the blobs). The third problem is that I don't know whether blobs that I would produce on my device would work on your device.
    The second and third problems we can test or read more about. The first problem we cannot solve, for that we need help from theandroidroot.mobi team. I found their github repository, which lists the five members of the androidroot.mobi team, i.e.,BuzzBumbleBee, RaYmAn, IEF, kmdm, and lilstevie. So, the next step, I think, should be to try and contact these people and hope that they are willing and able to help out with patching our bootloader.
    After that, there still is some stuff to figure out.
    The bottom line - this ain't easy and it might take time. Let's see what happens.
  3. mangusta
    mangusta Senior Member
    I managed to download a recovery for apx if someone needs it may post a link to files in zip format
  4. killer2020
    Would u p
    would u plz post the link and give us instructions on how to do it thx
  5. mangusta
    tests whether the tablet is recognized as apx Press power close tablet whole, and press vol + end vol - and power the tablet enters apx.
    if you have reached this point sends an email address to post a link to the rest
    work beter on xp or win 7 x86
  6. mangusta
    sorry for the grammar mistakes I used goole translete
  7. killer2020
    Actually it does recognize it in apx mode so what to do next
  8. mangusta
  9. mangusta
    the recovery is big aproximativ 950mb
  10. killer2020
  11. mangusta
  12. killer2020
    i cant understand anything plz tell me the instructions :):)
  13. mangusta
    off :)off:) off:), unzip to a folder, inside is a archive with a .zip file with drivers put the tablet in apx with Vol-, Vol + and power .use Win XP is more secure and install the drivers from folder then starts Recover ==== nvflash_cl2n_update_secure_boot.cmd
  14. mangusta
    It functioned give a sign if it worked
apx mode
fix nexus 7 apx mode
how to flash nvidia shield via apx mode
nexus 9 stuck in apx mode
nvidia shield tablet apx mode
nvidia tablet shield apx driver
shield tablet apx
shield tv apx
tablet apx mode
unbrick nvidia shield tablet apx
