Superpad i7 P745 (rooting need help)
Oct 11, 2012
Hello there! :)
Hi im new here but i know a lot of things on computer and rooting some android tab and phones, but i need a help here... My friend bought a Chinese Tablet and he ask me to root it. There is no Settings for USB Debugging mode so I Download the ShowVersions.apk So i can access the Hidden option "usb debug" then I tried to root it using GingerBreak first but nothing happened. Then I use z4root but it not work too. The last thing I do is use the SuperOneClick-v2.3.3
but an error occured:
Missing Driver! The following device does not have drivers installed: MID USB\VID_18D1&PID_1F00&MI_00
So please anyone help me rooting this device..
here's an Info about the device, i used the ShowVersion:
Hardware
Board : unknown
CPU
ABI : armeabi
Brand : Infotmic
Device : p745
Display : GRI40
Fingerprint : Infotmic/p745/p745:2.3.3/GRI40/eng.suixing.20331128.170834:user/test-keys
Manufacturer : Infotmic
Model : p745
Product : p745
Software
SDK : 10
SDK Code name : REL
SDK Incremental : eng.suixing.20331128.170834
SDK Release : 2.3.3
Tags : test-keys
Type : user
User : suixing
Host : fael
File system
FilesDir : /data/data/info.backx.showVersions/files
APK FilePath : /data/app/info.backx.showVersions-1.apk
External storage : /mnt/sdcard
Feature
Feature : android.hardware.wifi
Feature : android.hardware.location.network
Feature : com.google.android.feature.GOOGLE_BUILD
Feature : android.hardware.telephony
Feature : android.software.sip
Feature : android.hardware.touchscreen.multitouch
Feature : android.hardware.sensor.compass
Feature : android.hardware.camera
Feature : android.hardware.touchscreen.multitouch.distinct
Feature : android.hardware.bluetooth
Feature : android.software.sip.voip
Feature : android.hardware.sensor.proximity
Feature : android.hardware.microphone
Feature : android.hardware.sensor.light
Feature : android.hardware.location.gps
Feature : android.hardware.camera.autofocus
Feature : android.hardware.telephony.gsm
Feature : android.hardware.telephony.cdma
Feature : android.hardware.sensor.accelerometer
Feature : android.software.live_wallpaper
Feature : android.hardware.camera.flash
Feature : null
D
Dawnstar
Guest
Hello there! :)
Sorry to hear you having problems You said (Know a lot of things on computer and rooting some android tab and phones) The Chinese tablets are no different they are all made in China no matter what brand name you have, Also i don't use my (USB Debugging mode) Because it works fine with out it, if the Chinese tablet have problems try return it, if not then try to install another OS on it or maybe one of the Mods here can help you more
ahm.. then, i don't know about installing new OS on Android.. how should I do that?? and can someone teach how can i flash it.. I found some post on google about Superpad i7 and about ROM, Flashing. << It sounds new to me.. and also I found am update for my superpad: m701_4g_8188_256.ius . How can i burn? it to my tablet???
D
Dawnstar
Guest
This guide is only for the Rockchip RK3066 but it would help you a bit
https://dl.dropbox.com/u/106697397/how to install.docx
Here is another way
https://dl.dropbox.com/u/106697397/Cube U30GT-H flashing inx - Englang.doc
My Device has no Volume Buttons... it has only Power and Home buttong on side and Back button in front...
