Superpad Model # DISCO10 WIFI WILL NOT TURN ON....
Free2rade
Hello I hope someone can help me. I have had this superpad for 3 days, and all of the sudden I can no longer turn the wifi on. I have been using the wifi in multiple places like, the library, home, & work with no problem until today. I took it over my friends to show him & it would not let me turn the wifi on in settings. This problem continued when I returned home. Any advice?
dlzc
71
8
There is a slide switch on the "top" by the power switch, that turns the WiFi on and off. Is it fully on?
When you turned it off, did you use the menu (software) or the switch? You might have to make sure the software has been re-enabled.
I seriously distrust the physical slide switch in these units. I have heard horror stories about failed contacts and components that broke loose internally. I recommend you always turn it on and off via the menu.
Free2rade
That worked! Thanks a million!
gary65plus
12
I just got my superpad 3, 2.3 . I can't seem to get the wifi to pick up my wireless router? Any suggestions, also I didn't get a user manual. Where can I download one??
thanks.
dlzc
71
8
thanks.
This forum is for the Superpad / Flytouch II. Rather than just dropping a post in an unrelated forum, where people that can help you do not visit, why don't you find the right area to post in?
Choose something here:
SuperPAD Tablets
Destini96
My wifi dosent come on either.In the settings it dosent allow me to click and turn it on.
The switch is on and everything.Can anyone Help Me!?!
Superpad III
jeanb37
my tablet wont turn on....totally dead even after replacing the charger...only 3 daya old?
leeb
463
21
Unfortunately it DOES happen... even to the cheap stuff!
Contact your supplier for a replacement PRONTO!!! & make sure they know you had to get another charger... if they didnt send it to you!
:D
