delboy2028
- May 28, 2011
- 2
- 0
Hi guys just got a tablet from a friend and i am kinda confused as to who makes it and weather or not i can update it.
Its specs from the book are.
CPU: VIA WM8505
OS: GOOGLE ANDROID
MAIN FREQ: 300MHZ
MEMORY: 128M RAM
NAND FLASH: 2GB
SCREEN 7"
RESOULTION : 800 X 480
WIFI
USB PORT
MEMORY CARD PORT UPTO 16GB (8GB INSTALLED)
2HRS BATTERY
BUILT IN SPEAKERS AND CAMERA.
LABEL ON THE BACK SAYS MID
go to settings and about i get
model number : generic
firmware: 1.6
kernal version: 2.6.29-00236-g4f8dbbb-dirty
build: wmt2.0_710cu
So if any one can help with how to update or install custom firmware i would be greatfull even to just ID it so i can search for correct forum for stuff thanks
CPU: VIA WM8505
OS: GOOGLE ANDROID
MAIN FREQ: 300MHZ
MEMORY: 128M RAM
NAND FLASH: 2GB
SCREEN 7"
WIFI
USB PORT
2HRS BATTERY
firmware: 1.6
build: wmt2.0_710cu
