tablet unusable, help me to create rom for my tablet with my old backup
valker83
hello i have a problem, I need someone to prepare me a rom using my backup file I have of my tablet, on the PC, with file extension. img to load with live suit. can anyone help me? I installed a rom that does not run on my tablet and I want to replace my old one. this rom will not let me use the touch. my tablet is a TABLET PC 7 "ALLWINNER A13 1GHZ RAM 512 Android 4 ICS cinese tablet...
FEATURES
CPU
Cortex A13 1.5 Ghz
operating system
Google Android 4.0.4
memory
Integrated 4GB nand flash + Micro SDHC expansion slot up to 32GB
RAM
512MB DDR3
Display and video card
LCD TFT 7 "(maximum resolution 800 * 480) with automatic screen orientation - Mali 400 (good for gaming 3d)
camera
integrated 1.3Mpixel
connectivity
WIFI 802.11B / G
Steve1978
if the back up rom you have is already a img file you should be able to flash it with livesuit.....
i have also been looking for info on how to make/create img roms for livesuit on here but gotten no response yet....
i also have a chinese branded tablet and the other roms that worked with mine were the "mapan" roms.... so you could also look them up and give them a try?
sorry if im not much help but i hope that helps a little
