Telechips sdcard problems.
Discussion in 'Coby Generation 3' started by vampirefo., Jan 1, 2014.
  1. vampirefo.
    vampirefo. Senior Member Developer
    Huntington WV
    Leagoo Lead 1 ZTE OPEN C, Coby 7065, Coby 8042, Coby 9740
    Lets work on and fix this on going problem, I now have a coby 7036, I have just modified the vold.fstab.
    stock vold.fstab
    Code:
    # External NAND Storage
    dev_mount sdcard /mnt/sdcard auto /devices/virtual/block/ndda
    # External SD card
    dev_mount ext_sd /mnt/ext_sd auto /devices/platform/tcc-sdhc
    # External USB storage
    dev_mount usb_sda /mnt/usb_sda1 all /devices/platform/dwc_otg /devices/platform/tcc-ohci /devices/platform/tcc-ehci
    dev_mount usb_sdb /mnt/usb_sdb1 all /devices/platform/dwc_otg /devices/platform/tcc-ohci /devices/platform/tcc-ehci
    mine
    Code:
    dev_mount sdcard /mnt/ext_sd auto /devices/virtual/block/ndda
    # External SD card
    dev_mount ext_sd /mnt/sdcard auto /devices/platform/tcc-sdhc
    Code:
    root@android:/ # busybox df -h
    Filesystem                Size      Used Available Use% Mounted on
    tmpfs                   188.9M     32.0K    188.9M   0% /dev
    tmpfs                   188.9M         0    188.9M   0% /mnt/asec
    tmpfs                   188.9M         0    188.9M   0% /mnt/obb
    /dev/block/mtdblock2    380.0M    270.8M    109.2M  71% /system
    /dev/block/mtdblock5      1.5G    381.7M      1.1G  25% /data
    /dev/block/mtdblock4    512.0M      9.0M    503.0M   2% /cache
    /dev/block/vold/179:1
                             14.5G      1.4G     13.1G  10% /mnt/sdcard
                             14.5G      1.4G     13.1G  10% /mnt/secure/asec
    /dev/block/vold/240:1
                              1.4G    799.2M    586.0M  58% /mnt/ext_sd
    root@android:/ #
    rebooted and no problems, the tablet allows me to use the external micro-sdcard as and internal sdcard. So those with problems post in this thread what you did to your tablet, hopefully I can repeat it and fix it.
android ndda
