Tipstir's | Power Collection Package 228 | 1/21/11
Discussion in 'Gome Flytouch' started by tipstir, Jan 25, 2011.
  1. tipstir
    USA
    COBY KYROS 7015 | 7015A
    Supports Android OS 1.6, Android OS 2.0, Android OS 2.1 and Android OS 2.2
    Open Access Enjoy!
  2. syche15
    syche15 Member
    hi tipstir i m having problem with my pad it's WMT2.1_105 OS 1.6 firmware 256 ram via wm8505, it has large icon too slow and some app not working. so i flash the firmware with the lowest version 1.988.3 flashing seems to be fine all are successful but when i boot it nothings happen only black screen and green light lit up, i try a lots of firmware to flash in even the factory firmware it do the same problem they all successfully updated but nothing happen when i boot it black screen and green light only ....help please...i really love my pad
  3. tipstir
    USA
    WMT211 you can use WMT201 I don't recommend going lower you'll have mix results. Actually the larger icons are better you'll use less RAM.
  4. phisch
    phisch Member
    Illinois
    Android Mid 7"
    Tipster, Not sure if you were the one to post the rom MID7_2188 for the 1.6. generic version tablet, but my brick finally works. Works great actually. good speed camera good wifi good youtube as expected. touch and vibrate. damn near the real thing. My os is wmt2.1_88. I tried at least 16 versions till I got this one. Now I have your power package228. How do I get these downloaded to my pad. Not quite the master tech guy.
