Touchscreen not working Huawei Slim 7
zimsana
8
Dears
I need some help, my Huawei slim 7 touchscreen is not working after the installation of a 3rd party launcher
I have tried to install new firmwares ( MTN south Africa) & another one from Indonesia, but the problem persists, the touchscreen is not working & periodically some squares appear on the screen.
I have searched in the forum, and all the solutions tell you to root the device, my problem is that USB debugging is not enabled
Is there a way to root the device without usb debugging enabled ??
PS: I also tried flashboot, but it is not working
Thank you for your help
zimsana
8
Well when I press button ON + Volume Up, I have the flowing:
Enter into Flasboot mode
you can press Home + back to reboot the device
I don't know how to make a recovery from this point ? ( even home & back are not working from this window)
dzonikg
193
20
So you have a fastboot mode and how to flash recovery from that was writen 1 bilion times.
zimsana
8
Could you please send me a link that describes the method
I'm not able to find it
Thanks in adavnce
dzonikg
193
20
zimsana
8
Thanks for your answer, but i don't have usb debugging enabled, so trizet will not help
dzonikg
193
20
Of what usb debuging you talk about ???You just need to put it in fastboot mode..usb debuging has nothing to do with it.
zimsana
8
I downloaded TRZ mod and to make a fastboot the device is plugged with the usb cable to the computer, & when usb debugging is not enabled it doesn't work.
dzonikg
193
20
You dont now what are you talking about but ok..usb debuging has apsolutly nothing to do with flashing roms with fastboot.
zimsana
8
when I have the screen
Can you tell me what I need to do next ? from this window I'm stuck, & when I read in the forums there is a step when I need to connect the device with the PC, if you can show me a way to avoid that it will be much appreciated.
dzonikg
193
20
You want to flash rom from fastboot with out pc..you are genius of some kind ..i am finished in this topic.
zimsana
8
to connect the device to the computer, usb debugging should be enable for your information, it is not me the genius, it is you, you are answering to my thread just to make me loose my time, nothing you have said was helpful.
Please anyone else help me, is there a way to enable usb debugging from the computer directly ?
dzonikg
193
20
Thanks for your information..my usb debugging is not enabled but i install roms every day..no one can help person who dont now but think that he know..good luck.
tfmspm
I had the same problem with my new s7 slim after installing adw launcher. Installing new firmware via sd card rsolved the touchscreen problem......good luck!
