Transfer Box problems, no USB or Ethernet connection
Discussion in 'Infotmic Based' started by Curt_Lee, Dec 26, 2011.
  1. Curt_Lee
    Curt_Lee Member
    SFO
    MID 7 Tablet
    Hi All,
    I need some help please…
    I have the this tablet a Via 8650 Epad: Wholesale - Best selling Xmas Gifts Tablet PC 7 inch Via 8650 Epad 800M 256M 2GB Two point | **********
    From device information:-
    Model Number :- m799ca V2.0
    Android Version :- 2.3.3
    Baseband version :- unknown
    Kernel Version :- 2.6.35.7-InfoTM neville@neville-desktop #4
    Build Number :- m799ca-eng 2.3.3 GRI40 eng.petter.20111128.170033 test-keys
    Internet via Wi-Fi works and SD card read ok! The problem is I can’t get the USB/RJ45 “Transfer Box” to work. It don’t look like it’s interfacing because I don’t see LED light up on the USB thumb drive or LED on the modem to show that is a connection on the other end of Ethernet or see any existence of the two on the tablet. I know it’s the correct version (24 PIN) because the 3 groves fits and it only goes in one way. I tried to ask the seller but their English is really bad.
    The H/W is ok, I read some Transfer Boxes were factory faulty being too shout but this is not the case I tested this theory and it’s all the way in, when I disassemble it (taking out the shell) and pushed it in all the way.
    I’m thinking it’s the S/W, need a flash or I need to enable something. I brought 2 of these units and they both have the same fault.
    Any help will be appreciated, Thanks in advance,
    Curt
  2. budiprast180
    budiprast180 Member
    Indonesia
    Mid tablet via 8650
    Sorry if my English is Bad.
    My tablet Via 8650 and have same device information like you.
    I have same problems before, I think the transfer box is not really plugin properly and in this situation I try to open and release the box of USB/RJ45 “Transfer Box” with a screwdriver. I plugin to the tablet without the box and it's Work.
    You can try it and good luck.
  3. cck
    cck Member
    philippine?
    i am sorry your tablet is not the via 8650
    it is the infotmic processor so it not 3G USb if you get the ‘Sun sticker“ i am sorry it is bad quality there are many problem
transfer box for android tablet
usb transfer box android tablet
what is transfer box for android tablet
