UDROIDX 1.5.3 built on the 1.5.3 firmware WM8650 by EPAD-EKEN and MODROID V9
Discussion in 'WonderMedia WM8650 Tablets' started by lucsp, Sep 10, 2011.
  1. lucsp
    lucsp Member
    SP
    EPAD zx07d
    UDROIDX 1.5.3
    by Lucsp
    built on the 1.5.3 firmware WM8650 released by EPAD-EKEN
    (see website epad.hk model zx07d - see Pandawill Forum)
    based on Special MODROID V9 FW Lite by the Great Wicknix.
    Below is a list of supported devices . (Hopefully)
    USE CHANGER BAT TO CHOOSE.
    This list is still experimental with the 1.5.3 firmware
    1=Maylong M-250
    1=MID V7 7"
    1=InterToys NL Tab 7"
    1=MID E18 7"
    1=M009S Green LED 7"
    1=TomTec Tablet 7"
    2=M009S Blue LED 7"
    2=Generic Netbook 7"
    2=Epad GW-70 7"
    2=MIDV7 Blue LED 7"
    2=WinPad-C07 7"
    3=M003S 8"
    3=Innovatek MID 8"
    4=PC-802 8"
    5=BLY-806 8"
    5=VIA WM8650 8"
    6=M80003W 8"
    7=Apex 7"
    7=BLY-706F v1 7"
    8=MID703 7"
    8=ILC PC Tab701 7"
    8=KLD-MID701 7"
    8=MID710 7"
    8=EPAD ZX07D
    9=M010S 7"
    10=M012S 8"
    11=M70007T 7"
    11=ViaPad M7 7"
    11=VIA WM8650 7"
    11=M768A 7"
    11=Leader V70 7"
    11=Epad GW-707 7"
    12=ATF3416-7 7"
    13=BLY-706F v3 7"
    14=E16 5cun1603 5"
    15=ED99 8cun1603 8"
    16=E18 7cun1603 7"
    17=ED99 8cun8900 8"
    18=Ricatech/RATAB10 10"
    18=TomTec 10"
    19=Epad M009D (added by ohwzo.nl)
    20=M013S (added by me)
    To install do the following:
    Format a SD card to FAT32
    Extract the contents of the zip file to your SD card.
    If you do not use Changer.Bat ( I DONT) , I am sure you are able to do the following:
    Choose your env.uboot file under Firmwareinstalle/env according your device and rename env_uboot, delete all the other you have founded in that directory.
    BEFORE FIRMWARE UPDATE back-up the env_uboot and wmt_scriptcmd files from your devices factory firmware you could need it later !!!
    Insert SD card into your device and power on
    The upgrade will run automatically. When it’s finished wait about 45 seconds before removing your SD card when it tells you to. The device will reboot (first boot after upgrading may take few minutes)
    Use at your own risk!!!!! Use at your own risk!!!!!
    If you get stuck at the system loading screen for more than 5 minutes try another env_uboot or use the env_uboot and wmt_scriptcmd files from your devices factory firmware.
    TIPS from the Great Wicknix:
    If you have NO sound after flashing try this fix:
    Edit the env_uboot file you used and change this....
    "setenv wmt.audio.i2s vt1603:f1:f2:ff:ff:100" to this "setenv wmt.audio.i2s vt1603:f2:f1:ff:ff:100"
    Save and reflash.
    If your camera doesn't work try this fix (works on most devices):
    "setenv wmt.gpo.cmos 1:0:7:D8110040:D8110080:D81100C0" to this "setenv wmt.gpo.camera1 1:0:7:D8110040:D8110080:D81100C0"
    Save and reflash.
    Known BUGS:
    1) I was not able to fix battery monitor.
    and probably a lot more ............................... but we do trust in future !!
    IF WIFI Is not scanning:
    1) Download the latest rt3070sta.ko file http://www.mediafire.com/?obnigwbhk344b7c
    DIRECTLY to your device, or to an SD card
    2) using RootExplorer (or even the shell!!) rename the file from rt3070sta.txt to rt3070sta.ko
    3) using RootExplorer (or the shell) copy the file directly into the /lib/modules/2.6.32.9-default/ directory
    4) re-open the WiFi Settings App, and enable WiFi
    Thanks to Wicknix for his special MODROID V9 and EVERYBODY else!
    Also thanks to yochenhsieh for the GREEN wmtlauncher.
    UDroidx153 FINAL
    http://www.4shared.com/file/S2V2CcGB/UDROIDX153_final.html
    UDROIDX153_fH
    (fastest, improved wifi and battery) you can find Flashplayer in system/app and install it works perfect)
    http://www.4shared.com/file/Ep0myfKk/UDROIDX153_fH.html
    Try new 1.5.5 build
    http://www.4shared.com/file/f28jFfRl/UDROIDX_155_U.html
Download changer bat
modroid
modroid download
modroid green led
modroid v11
modroid v11 download
modroid v11 lite
no sound for wm8650 netbook
WM8650 Firmware Download
wm8650 wicknix
