Ultralight Android Edge powers off when AC adapter is unplugged
Discussion in 'Android Tablet Q&A' started by thump69er, Oct 3, 2012.
  1. thump69er
    thump69er Member
    Oct 3, 2012
    Samsung Galaxy 10.1, 7" A13 MID
    I recently got a 7" Ultralight Android Edge from a Directbuy Promo. I charged the Tablet over night and it was working fine. My daughter was surfing the web and the tablet shut off. If I plug in the adapter it boots fine but when it is unplugged it shuts off. With the adapter plugged it says charged and when I check the battery it says 100%.
    It is a Chinese Tablet and the box has Android MID label on it.
    under about the following info is present
    Model # A13-MID
    Android version 4.04
    Baseband 1.5
    Kernal 3.0.8+
    Build Nuclear_pfdq88c-eng 4.04
    1. I reset the tablet to factory setting with no luck.
    2. I have searched the forums for a hard reset method with no luck.
    3. I have held the power button down for 45 sec
    4. I have held power button and volume buttons down with no luck.
    Any suggestions would be greatly appreciated
  2. Dawnstar
    Dawnstar Senior Member
    Sep 5, 2012
    United Kingdom
    Samsung GalaxyTab2
    It could be the tablet batteries are not holding a charge 100%, and you don't need to charge the tablet over night all it needs is two hours or less if i was you i would return it if you can.
hard reset ultralight android edge
how to reset an ultralight android edge tablet
ultralight android edge factory reset
ultralight android edge hard reset
ultralight android edge playstore
ultralight android edge reset
youtube ultralight android edge powers off when ac adapter is unplugged
youtube ultralight android edge reset
