[Urgent Help Needed] Touchscreen not working after Updating
Discussion in 'Huawei Ideos S7 Technical' started by chipside, Aug 31, 2011.
  1. chipside
    chipside Member
    Great day to all...
    my touchscreen is perfectly working. after i update to official Indo 2.2 update and follow perfectly everything to it detail and reboot... then after the IDEOS Logo a touchscreen calibration appears but i really can calibrate the screen because the orange cross is not responding... any help will be appreciated.
  2. chipside
    chipside Member
    damn... i already fix it when i pressed Menu+send+power key then after upgrading again on official 2.2 update i loose the touchscreen again and the Touch screen configuration appears again... anyone can help to solve this problem? even i get back now to the old 2.1 Sweden i already lost the touchscreen...
  3. pa49
    pa49 Senior Member
    UK
    Huawei S7, Nokia X3-02, Nokia E71
    What model and what ROM version?
    Sent from my Blade using Android Tablet Forum
  4. chipside
    chipside Member
    i have a Ideos s7 with a capacitive touchscreen. right now whatever rom i flash it is no use... a friend told me i need to flash the original stock rom. does anyone have a stock rom? links posted on the sticky thread are already dead...
  5. chipside
    chipside Member
    by the way... i am from Philippines and my tablet came from a package plan from globe Philippines.
  6. chipside
    chipside Member
    hmm... 200+ view without any response? I ask on the other site... they told me that the possible problem is in the "KERNEL" they are investigating on it right now... I really don't that the touchscreen is broken... because whenever i flashed new Firmware (2.2) it works for a while then after 1 to 2 days it will stop working... sometimes it wont work even i flash 2.2 rom they advice me to flash stock rom 2.1 but it is nowhere to found right now... does anyone care to help uploading 2.1 stock rom for s7-105?
  7. Tom T
    Tom T Senior Member
    Washington State
    Hauwei S7
    I know a site that keeps an index of S7 roms but I don't have acvess to the info tonight, I will post it here tomorrow. Sorry you didn't get the info you needed but I think your problem may be somewhat unique. I honestly can only guess that some app you are running could be the cause.
  8. Edgeman
    Edgeman Member
    Australia
    Any solutions?
    Similar issue with a friends Tablet ...
    Australian Telstra touch tab S7-104
    (Huawei)
    firmware 2.1 update1
    baseband 6285
    AMSS VERSION 4076
    KERNEL 2.6.29-S7
    BUILD S7V100R001C13B021
    First 4 calibration crosses work ok, but last centre cross #5 only works when I tap about 1cm to the right in landscape, or under in portrait - otherwise it just blinks if I click on it.
    In use, when selecting an icon in landscape, it selects the icon to the left - callibration is constantly out & is worse in the centre of the screen.
    I have tried a hard reset and a factory reset but doesn't fix it.
    Cheers.
    [EDIT]
    Last night I flashed 2 new ROMS onto the S7:
    - Norwegian 2.2.2 S7V100R001C57B111 ROM
    - Huawei Ideos S7 official firmware (2.2.) S7V100R001C13B115 (Australian Telstra)
    The same thing happened. It would appear that this is most likely a hardware issue.
cloudfone touch screen not working
cloudfone u8350 touch screen not working
huawei touch screen firmware update
huawei u8350 touch screen firmware update
huawei u8350 touch screen not working
huawei u8510 touch screen firmware update
huawei u8650 touch screen firmware update download
huawei u8860 touch screen firMware
huawei u8860 touch screen firmware download
huawei u8860 touch screen not working
huawei y210 touch screen firmware update
huawei y210d touch screen firmware update
touch screen firmware update huawei
touch screen firmware update huawei u8860
touch screen firmware update huawei y210
touchscreen firmware update huawei
touchscreen firmware update huawei u8350
touchscreen firmware update huawei y210
u8860 touch screen firmware update
y210 touchscreen firmware update
