djonathang
- May 19, 2011
- 24
- 0
Hello All,
I am absolutely giddy. With the help of the forum, I just rooted my Nook Color with CM7. This came after some pretty frightening hours of a very expensive doorstop.
I'm surprised by one thing in particular. I had no idea that using my gmail account would result in a mirroring of apps on my Droid X. I like it!
My question now has to do with accelerating my device. I believe there is software that will do this - "Clocking"? If so, do I simply add this to the SD card I used to root, and then add it, or do I have to start over every time I add a feature such as that?
I know this is probably either basic, totally confused, or idiotic, but I'm green as they come, and learning a tremendous amount. Your mentoring is truly appreciated!
Thanks.
David
Thanks.
David
