Volume button hard to press?
pentool
93
Do you guys find that the volume button at the top is very hard to press? Wonder if that's a common issue or just on mine.
pentool
93
Ok, so I just took a breeze walk down to BestBuy to check out their display and on that, the volume buttons are very easy to press. They even have a soft "click" to them when you press them. I'm debating if I should do an exchange just for this. Maybe I end up with a same unit. That's why I wanted to find out what others have.
Garemlin
Super Moderator
93
Compared to the Xoom the volume button is easy to press. But even not comparing I don;t find it hard to press at all. The one on the Xoom is a flat-out PITA.
pentool
93
I exchanged mine with a new unit. This one has a good button. Definitely different.
pentool
93
I know. I asked myself the same question. But then I decided that for $450 + tax it DOES bother me.
Jento
22
Mine is pretty easy to press...
I have read this on some of the reviews about the a500.
