WaterGuard Plus Waterproof Case for NOOK color
Discussion in 'Nook' started by rico2001, Dec 11, 2010.
  1. rico2001
    rico2001 Senior Member
    Charlotte, NC
    NOOKcolor
    • Like Like x 2
  2. gadgetrants
    gadgetrants Moderator Staff Member
    Asus OG Transformer, Droid 3
    OMGWTF?
    -Matt
  3. mgr52
    mgr52 Member
    Illinois
    Apad 710
    wow, I wonder how well the screen works with the cover
  4. idontknow
    idontknow Alternate ATF App Tester
    miami,fl
    galaxy note,galaxy 8.9 ,nook color
    I'm wondering about that as well,. Going to check there return policy....I'd love to take my nook to the beach since I live by the beach. It looks funny though...
  5. RaVenJ
    RaVenJ Senior Member
    Nook Color
    Just an FYI... Two days after buying my NC, my 5 year old spilled a glass of water directly on it. It was standing on the screen. My wife found it and dried it off. They brought it to me and she confessed through her tears what she'd done. We all assumed it was fried. I pushed the button and it came on as normal. The NC is tougher than people think. And yes, I still let my girl play with the NC.
  6. gadgetrants
    My 9-year-old did almost the same thing with her Asus netbook. Now a few keys are REALLY sticky (inside, I mean), but otherwise it's dried out!
    -Matt
  7. jaythedogg
    jaythedogg Member
    Iowa
    Nook Color
    I know the feeling. :p
    My 3 year old, when he was just turning three, escaped my sight, peed IN my computer keyboard whilst standing on my computer desk. :p
    Then there has been soda spills, (mostly my fault) milk, juice, etc. All in my keyboards. I pluralize that because I went through so many that I stopped buying keyboards new & stock up on the used ones from GoodWill cheap.
    My suggestion? For her netbook, take a picture of the keyboard so you remember the exact layout of the keys, then one by one with a butter knife, gently pop each on off.
    Then grab a bottle of rubbing alcohol & cotton swabs & start cleaning EVERYTHING in the keyboard tray & along the sensor rubber.
    That or buy her a USB keyboard to plug in. :p
    Oh yea & have the netbook off until you are done. :)
    Then soak the keys (1 layer at a time) in rubbing alcohol for a few minutes & shake them off & rub them with a rag to remove residues.
    Not trying to derail the thread, just been there, done that, got some tips. :p
  8. AnimaTechnica
    AnimaTechnica Senior Member
    california
    Droid, Haipad 701, Rooted Nook Color
    lol i remeber a friend of mine's kid was playing with the PC, and pretended the pc had a mouth - yes he opened the DVD drive and fed it oatmeal
  9. gadgetrants
    AWESOME! Thanks for the cleaning instructions. But you're joking about the pee, right???
    -Matt
nook color water proof case
nookcolor waterproof case
