Wi-Fi Disconnect When Using Bluetooth
Jun 29, 2011
135
I first want to say the Note8 is by far the best tablet I've ever used.
I do have a question though about a possible bug somewhere.
When I'm using Bluetooth for music, have multi screens open with Power Amp being one of the screens, my Wi-Fi will disconnect when idle and will not reconnect until I turn off Bluetooth or reboot the device.
I am stock, non rooted, 4.1, using Nova Launcher, 2.4 ghz on Linksys e1000 router with latest firmware and a strong signal when it drops and it only happens with the above scenario. From that point it says the router is out of range until I do the above written work around.
I know I could just not run Power Amp in the multi window but it kinda defeats the purpose of multi window if I have to pick and choose which will work without bugging up the device.
Thank you very much for your help
Support Our Troops!!!
