wierd udb hdd
Discussion in 'Gome Flytouch II Accessories' started by enochian, Apr 20, 2011.
  1. enochian
    enochian Member
    superpad
    i have a 320 gb sata hdd from a laptop connected to a usb portable hdd connector from a broken 1tb external hdd the only problem is it shows only 2gbs with files iv never seen before any way to fix this
  2. Campaman
    Campaman Member
    Are you sure that the file explorer is looking at your USB drive, as that size and files you haven't seen before point to the fact that you are looking at the pads internal storage
  3. Appychappy
    Appychappy Member
    australia
    infotmic superpad 2.1
    Tablets don't recognise hard drives, only usb flash drives and sd cards
  4. enochian
    enochian Member
    superpad
    I hear formating the hdd to fat 32 works. I believe I'm. Seeing a 2gb windows boot partion since they are windows files or maybe its the
    recoverly partion
  5. enochian
    enochian Member
    superpad
    recoverly partion
  6. Appychappy
    Appychappy Member
    australia
    Well you could format it to fat32 but if you are seeing files without a question mark they are fat 32.
    But I think it is the system drive you are seeing or an sd card. In any case do you have a 2gig partition on the h. drive?
