wifi connection problems
Discussion in 'Android Tablet Q&A' started by linda_01b, Oct 15, 2012.
  1. linda_01b
    linda_01b Member
    stoke
    mid google android 2.2 7"
    Hi im a newby to this site and also new to tablets. I bought a mid google android 2.2 7" tablet for my 4 year old daughter for xmas but i cant get it to connect to the internet via wifi although it says excellent signal, scanning, connecting, disconnected argggghhhhh doing my head in now. please help
  2. leeshor
    leeshor Senior Member
    Norcross, GA
    Samsung Galaxy Tab S 10.5
    Welcome to the forum
    The good news, it would appear your tablet is working fine. There are several things that could be causing the problem. Everything from the router needing to be restarted to incorrect security settings. I have a link in my sig below that should help get you connected.
  3. Spider
    Chicago, IL
    Hi Linda, welcome to the forum. Glad you decided to join us here at Android Tablets. I'm fairly certain following the instructions linked to in Lee's signature will take care of your connection problems. However, in the event you need additional assistance, I'm going to move your thread to the Android Tablet Q&A section where more people are likely to join the discussion and try to help you. Good luck!
