Wifi issue w/CM7 Beta 6.3 on TC970
Discussion in 'Le Pan Development' started by rtangwai, Dec 30, 2012.
  1. rtangwai
    rtangwai Member
    Toronto, ON, Canada
    Le Pan TC 970
    First post, new to Android tablets so if this isn't the correct forum to post I apologize in advance.
    I got a Le Pan TC 970 tablet a while back, which I found barebones but usable in most situations (wouldn't play back HD content without stuttering). The limitations of 2.2 made it annoying enough that I started to look at newer 4.0+ tablets, but in the meantime I decided to see how far I could go with this one. I installed the CM7 Beta 6.3 as per this forum's instructions (using the original 2GB card). The instructions are very clear and detailed and I had it running fairly quickly other than a moment of panic when I realized the custom ROM had to be unpacked on the SD card rather than in zip format. I followed *ALL* the instructions (clearing the caches, etc.).
    The CM7 ROM is working great, looks and behaves a lot better than 2.2 with one major exception, the wireless. While it never claims to lose connection (the signal icon clearly shows it is still connected to my wireless), I find the connection frequently stalls and I have to turn it off and on to get it working again. I poked around but I cannot find any extra settings for the wireless to adjust in the tablet. I am using a Sagemcom F@st 2864 router/modem. Anyone have any problems connecting to this particular router? I'd prefer to narrow down the problem before I start throwing money at it as I just got laid off and honestly I'd prefer to eat rather than get the wireless fixed on my tablet.
    If absolutely necessary I would flash it back to stock - are there any instructions as clear as the CM7 thread on how to do this?
    Thanks in advance!
