Wifi not in range
Discussion in 'Android Tablet Discussions' started by hulkhogan777, Jan 27, 2013.
  1. hulkhogan777
    hulkhogan777 Member
    ireland
    desire tablet 4.0 android 9.7 screen
    hi again , since my last post have done a bit of travelling with my DESIRE TAB have been in several hotels but am having trouble with wifi connection
    when in hotel room cannot get internet keep getting !! not in range !! and its happened in all hotels ,is there any settings that I need to change or am I able to boost signal with app ,hope someone can help.
    thanks in advance
  2. leeshor
    leeshor Senior Member
    Norcross, GA
    Samsung Galaxy Tab S 10.5
    I'm wondering if you tried those hotspots by opening a browser, (normally the preferred method for most) or by going to settings -WiFi?
  3. t.anderson
    t.anderson Member
    When you have the wifi install the app wifi fixer. This app will solve all the wifi problems of your device.
  4. hulkhogan777
    hulkhogan777 Member
    ireland
    thx for replies but since I got home now I cannot get wifi at all ,it picks up my wifi signal and when I click on it its not in range !!! ,am only a foot away from modem .
    any help please
  5. leeshor
    Norcross, GA
    I;m guessing that before you went and used the other hotspots that it worked at home. You might want to check some of the tips in the link in my signature to see if something clicks. If it is a persistent problem I suspect an app may be at fault. Have you installed any app that would have helped you tether to a phone or any firewall apps?
android tablet wifi not in range
my wifi is not in range on my tablet
samsung wifi not in range
wifi not in range
wifi not in range android
wifi not in range error
wifi not in range for tablet
wifi not in range problem
wifi not in range samsung galaxy
