WIFI Problems
alarsen0002
My novel7 e-reader won't connect to wifi. Shows up under wifi settings as having full strength, but won't connect. The meter shows up full in white, and sometimes a wifi icon with a question mark appears.
blackcoupe01
153 views and no replies ??? I came here looking for help with the same problem, not feeling lucky already :( My supernova will not even attempt to obtain IP info.... my wife also has the same tablet, works fine. Mine will only work for a short while IF i restore to factory defaults. After adding some apps, nothing crazy just a few games, i fail to connect, WTF I know there has to be a fix for this without having to wipe out all my stuff by restoring to factory default... help would be much appreceiated, thanks
