Wifi signal issues.
LordBane00
21
Is there any Way to fix the wifi issues on the 7015 I keep having problems keeping any signal when 10 or more feet away from router or hot spot.
Joey1320
82
I'm not experiencing those issues and I'm 20-30ft from my router.
Have you consider having the tablet warrantied?
chicle
13
Have you installed updates? Have you rooted your tablet? If you haven't, do so. This might solve your problem. There are step-by-step instructions on rooting and installing Google Apps in this forum that are easy to follow.
fxdominicano
19
Its only 2 days old are they so bad that it needs to be warrantied so soon?
You don't need to change the tablet, just get another router that can work as repeater to help you improve the quality signal
