wifi signal strength
chilipalm
Anybody have problems with the wifi signal strength? When I go to the next room away from the router, the signal drops to one bar. My laptop and iPhone show full signal strength.
pbrauer
3,649
561
Is your tablet antenna covered?
Sent from my VEGAn-TAB using Android Tablet Forum
chilipalm
I don't think I'm covering it. Where is the antenna located? Maybe I'm holding it wrong...
Icebike
1,523
186
The best solution is to stop looking at the bars! ;-)
Seriously, there is no standard relationship between signal strength and bars.
chili_red
22
I'm presently in my back yard about 75' from my router and its working fine, the signal does disconnect if I go any further. I've found that there are big differences in wifi ranges with different makes and models. I'm currently using a Netgear e2000, my old wrt160n couldn't reach this far.
fulaccer
mine is also kind of slow in some places only, in my house i have the normal att router and it works fine.
