WiFi Woes!!
J
jimbo7630
Guest
For anyone plagued by constantly disconnecting from WiFi - try re-entering your Router's Password (it may have become corrupted, or, like me you may simply have entered the wrong password!) After a Factory Reset I had to re-enter my WiFi Router's password which I did several times with no joy. Only when I got out my trusty magnifying glass did I discover that the first 8 was, in fact, a 6. Problem solved!! Red Face remained.:mad:
J515OP
Super Moderator
5,172
899
I shouldn't laugh but you are not the only one to get caught. What is worse is some keyboards will automatically add a space after the last number. That is a hard one to spot.
chainmeup
I always seem to get caught out by the autocorrect, you really have to look and see if it has changed what you tyed before pressing enter. Very annoying at times :(
