Wifi won't turn on
emdorsey
Hi everyone. I just ordered an Android MID device off of nomorerack.com (which is probably a sketchy place to get something like this anyways) and I used it for one day and it connected to the wifi fine but now the wifi won't even work on it. The actual wifi part of the tablet won't turn on. I will go to Settings, click on wifi, press On, and all it will say is "Turning Wi-Fi on..." But nothing ever happens! The button will just go from the On position back to Off. I've tried doing a Factory Reset numerous times, I did a Reset using the Reset button on the back of the tablet many times, and still nothing. It's so frustrating. Help me?
Model Number: M9000
Android Version: 4.0.4
Baseband Version: 1.5
Kernel Version: 3.0.8+
Build Number: nuclear_evb_eng M9000 20121107
leeshor
6,330
1,037
Welcome to the forum
It's possible an app is getting in the way, (but not all that likely). In order to determine if you have a hardware problem or not you would need to do a factory reset. If you have any data on the tablet you would need to copy it to your PC using the charging cable.
