Witstech charger - specs or replacement needed
Discussion in 'Witstech Tablets' started by hepps, Nov 17, 2010.
  1. hepps
    hepps Member
    NULL
    Hi all,
    Happy owner of a Witstech A81e and left my charger overseas. Are there any compatible chargers that will work? Or where can i get a replacement charger?
  2. gurgle
    Near 39.11°N 94.6°W
    Interesting factoid about the chargers that come from the sellers.
    OutPut for Wall charger: 6.5V 1.5Amp
    Output for 12V Car charger: 5V 1.5Amp
    So, it looks like it is the end which is critical. It looks like center is POS. and that it can be 5-6.5V with 1.5Amp output
  3. davawt
    davawt Member
    Cheshire, UK
    Wits A81
    Hi there
    Also the end of the connection is Dia: 1.5 mm and its length: 8.00 mm
    That fits the female on the wits A81e, hope this helps?
    Take care, bye
    davawt
  4. vijaykhai
    vijaykhai Member
    Los Angeles
    Wits A81E 2.2, Rooted
    I have been using my Wits A81E since Aug. 2010 (small USB) and quite enjoying it. However for the last couple of days the AC power charger has been giving trouble - appears to be with the end plug which goes into the A81E side, loose connection? Shaking it and pressing hard etc. seems to work, when the power switch comes on, otherwise not charging.
    Can I buy in USA an alternative, if so details please. Many thanks in anticipation.
  5. Barry S
    Barry S Member
    England
    WITS A81G
    The charger is rated 5V @1500 mA DC, which is hard to believe looking at the DC cable. The DC plug is a 3.5mm DC barrel. I have used a USB mains charger with a USB to 3.5mm DC barrel cable to charge my A81G. You may have a problem charging it from a PC USB port as they generally have a low current output. Hope that helps.
  6. jdcorley
    jdcorley Member
    Atlanta
    Witstech A81G
    FWIW, my miniUSB charger for my phone will not charge in the miniUSB slot. I haven't tried the big USB slot. (just thought about it right this instant!)
    I also haven't found a replacement charger anywhere (RadioShack, Batteries+, etc.)
  7. gurgle
    Near 39.11°N 94.6°W
    WitsTech in their glory do not use over the wire (USB connected) charging. You have to use a charger. My AC unit died so rely totally on my 12V charger and a AC/12V DC socket converter.
    I also found a USB to the plug adapter. I can charge but not use the device this way. It is a trickle charge effect and takes about 2X as long.
  8. tetrarca1
    tetrarca1 Member
    Virginia
    A81 WITS TABLET
    can anybody tell me where to get a wall charger for my a81?​
  9. fatmanwalking
    fatmanwalking Member
    Huntington Beach, CA
    Sylvania Mini Tablet Express
  10. tetrarca1
    tetrarca1 Member
    Virginia
    A81 WITS TABLET
    Did it work? I've been trying to get a car charger for my WITS A81, can't find it anywhere. The one online its says that is white in color, its that the right one? (fatmanwalking) where did purchased your and how much they charge you for it? Did it work?
  11. fatmanwalking
    I bought my charger (wall charger not car charger) from Merimobiles.com. I also purchased my A81H from Merimobiles.com as well.
    Even though the description is "White", what I received was exactly the same as the black wall adapter that came with my A81H. I was bummed as I'd wanted a stand alone battery charger, like the ones to charge those rechargeable AA batteries. No matter as I now have a spare and it didn't cost me that much. I just have to charge my spare battery using my A81H tablet.
    I suppose you could always try emailing the guys at Merimobiles with a question before you pull the trigger, but at $15 and free shipping, I wasn't out that much. Uh pardon me for asking the obvious, but didn't you try clicking on the link I provided? All of the information you asked me comes up on your screen. (I just tried the link now.)
charging cable for a jinhan a81 phone
wits a81 replacement power button
