WM8650 camera problem
jinxas
Hello, I've just received my WonderMedia WM8650 7'' 4GB 512MB tablet from china and everything seems to be fine except my camera. When I launch my camera app, screen goes somewhat green and after a few seconds the tablet hangs up and I need to restart it by using on/off button. Is it mostly like camera hardware problem or it may be software problem? Does anybody had similar problems? All I know about camera that it is 1.3mpix and Android System Info app says about my camera "As retreiving camera infos can give impression that it is taking picture on some device, it is not enabled by default. If you wish to, go in settings menu". Does anyone have any ideas? Camera view can be seen at Image - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
Android 2.2
Kernel 2.6.32.9
Build number 1.5.3
gl3nborj
Try to apply some pressure on the camera hole side, maybe loose connection. Camera is socket type connector.
