WonderMedia WM8650 - ethernet problem
Discussion in 'WonderMedia WM8650 Tablets' started by rudiger, Jan 30, 2012.
  1. rudiger
    rudiger Member
    gloucester
    wm8650
    Hi
    Just got a WonderMedia WM8650 and want to connect to Internet, have tried DHCP and manual IP setup but no joy.
    Android 2.2
    Kernal 2.6.32.9-default
    Build generic-eng2.2 froyo ver 1.5.5-20110920.083830
    tks
  2. jimbo7630
    jimbo7630 Guest
    Top Poster Of Month
    Sounds like you have no PC connected and no Router with WiFi??
  3. Spider
    Chicago, IL
    Hi Rudiger, welcome to Android Tablets. Glad you decided to join the forum. I'm going to move your thread to the WonderMedia Based forum for you to see if anyone there can help you out. Good luck
  4. rudiger
    rudiger Member
    gloucester
    wm8650
    OK - I am connecting my cable modem ethernet port to the "add on" ethernet port on the WM8650
  5. rsalter1
    rsalter1 Member
    Hartwell, Ga
    eglobal electronics android tablet
    Does your plug in USB and ethernet port actually get seen by the tablet? (Can you plug in a USB memory stick and the tablet recognize it?)
    Try turning the tablet off completely. Connect the add on, making sure it's firmly plugged in. Turn the tablet back on. Go to settings and ethernet. Turn ethernet on Then plug in the cord from the modem. You SHOULD see the available ethernet then in the ethernet setup choose DHCP and your tablet should connect.
cara setting wondermedia wm8650
configure wondermedia wm8650 for internet browsing
connect wm8650 to ethernet
connection setting ethernet for wondermedia wm8650
how to configure ethernet connection on wm8650
internet en un wondermedia wm8650
who connet internet in wondermedia wm 8650
wonder media w8650 tablet internet ayari
wondermedia tablet internet configuration
wondermedia wm8650 manual
