wondermedia wm8650 power problem.. I NEED HELP PLEASE
educlassic
I got a WM8650 tab (red charging light and green power light) the battery went empty and it wont power on after about 6 hours of charging. I tried every button combination options to no avail, then I pressed the reset button while charging it and it powered but since then, it does'nt power on except I use d reset button and its pluged to power supply. Once its powered, it can run on battery but can trip off anytime and will require pluging to power source and pressing the reset button again. once is on again on battery, the battery level still remain the same. it just wont power on with battery and it keeps triping/goin off every 30mins. pls I want to know what to do. thanks a million
educlassic
I think its a battery problem, Please can anyone tell me how i can purchase replacement battery. (the battery is blue, rectangular, has two 3.7v joined together). Please I need this device functioning again.
