Working bluetooth GPS signal FROM PHONE
Discussion in 'Archos Tablets' started by Bilgediver, Jul 6, 2011.
  1. Bilgediver
    Bilgediver Member
    VA
    Archos 70 250 GB, Nook Color, Motorola Droid2Global, Droid 1
    Requirements: Archos gen8 tablet with built in Bluetooth GPS feature.
    Android powered smartphone
    "Bluetooth GPS Output" from the Android market (Developer Meowsbox) installed on your phone.
    -free version lasts 10 minutes
    -paid version costs $1.57?
    Step 1: Bluetooth Pair your phone and Archos tablet (I have the Archos 70 250 gb)
    Step 2: Open Bluetooth GPS out on your phone,and turn it on, you should see a screen showing satellite info
    Step 3: Archos Settings/Location and Security/Bluetooth GPS, then select my paired phone. If that is grayed out, try opening up the app on your phone before actually pairing your Archos with your phone.
    Step 4: Open up maps and enjoy the Navigation!
    I've got it tethered wifi, too, so I've got Bluetooth GPS and data, its like a 7 inch Garmin or TomTom!
    Sent from my A70H using Android Tablet Forum
  2. Bilgediver
    Bilgediver Member
    VA
    There are numerous apps for receiving a Bluetooth GPS signal on the market, but this is the first I've seen that does he opposite. There might be others, and if you know of any, please share!
    Its cool that Archos included a Bluetooth GPS receive function built-in!
  3. ja2038
    ja2038 Member
    NULL
    Worked very easily between my Nexus One and my Archos 70IT.
    THANK YOU!!!
share gps signal android
sharing android phone gps to tablet bluetooth
