Zeepad 7.0 WiFi Connection Problem
Discussion in 'Android Tablet Q&A' started by mcullison, Jan 19, 2014.
  1. mcullison
    mcullison Member
    Fort Bragg NC
    Zeepad 7.0
    Just bought two Zeepad 7.0 today. One connected to our wifi with no problem, the other one won't. When we go into the settings and slide the wifi from off to on, it stays there for about 10 seconds and then slides itself to off. I have already tried to do a reset to factory settings and that didn't help either. I have looked at other settings and can't see any reason why it is doing this. Suggestions....?
  2. leeshor
    leeshor Senior Member
    Norcross, GA
    Samsung Galaxy Tab S 10.5
    Welcome to the forum
    Since it's so new, do a factory reset. If that doesn't work check on a public hotspot and if you have the same problem there get it exchanged. This assumes both have the exact same versions of the firmware. (settings - about)
  3. mcullison
    mcullison Member
    Fort Bragg NC
    Zeepad 7.0
    Have already tried doing a factory reset. I thought about trying somewhere else but like I said the button won't stay in the on position any longer before it turns itself off.
  4. Spider
    Chicago, IL
    Hi mcullison, welcome to the forum. Glad you decided to join us here at Android Tablets. It sounds like it's defective, return it.
android zeepad 7 wifi not working
wifi connection on zeepad 7
wifi not working on zeepad
zeepad wifi connection
