Zenithink C91 Upgrade Volume and Camera Don't Work
Discussion in 'Zenithink ZT280 C91 & C91 Upgrade' started by missflawed86, May 10, 2012.
  1. missflawed86
    missflawed86 Member
    TN
    Zenithink ZT280 C91 Upgrade
    I just got it today so I'm mostly playing around on it but I noticed the camera won't work. It keeps saying camera will not work in HDMI mode even though HDMI mode is off. Also the volume doesn't work at all, for anything. What could be causing these problems?
  2. oldsalt
    oldsalt Member
    Adelaide Australia
    Chinese
    Try re-flashing the unit.
    Get the rom here Zenithink
    I also had no sound, I traced it to Titanium Backup, are you using it?
  3. xtremeculture
    xtremeculture Member
    Puerto Rico
    Have you tried the solution in the post "Netflix and ICS"? My C91 Upgrade had problem with the audio and that XML File solve it. Hope it help.
  4. cpender
    cpender Member
    Kinston, NC
    Nook Color
    I did install Titanium Backup and unistall it thinking sound will come back but nothing. did you resolve the sound problem?
upgrade volume tablet
zenithink c91 no sound
