Zenithink Epad/ZT180/M16 Android 2.1 1014 Firmware
Discussion in 'Zenithink ZT180 10 Generation 1' started by jtshop, Oct 16, 2010.
  1. jtshop
    jtshop Member
    china
    A81 E/HSG X5A/Epad
    1.Support google market.(Please make sure to set the correct local Date and Time)
    2.Update the google map.(Please make sure to set the correct option: touch "setting"->"Location & Security"->"Use wireless networks"<display ticker>)
    3.Update the touch screen calibration : dev tools -> ts_calibrate,touch 5 cross(+),then press the return button
    4. update calendar_clock
    1, uboot.img : uboot
    2, zImage
    1) zImage_1024x600 : linux kernel , resolution 1024x600
    2)zImage_1024x576 : linux kernel , resolution 1024x576 choose right zimage
    3, system.img
    4, userdata.img
    download
    download
    Zenithink Epad/ZT180/M16 Android 2.1 1014 Firmware : Android
  2. StepLaugh
    StepLaugh Member
    NULL
    This is great and all...but
    how do I install it to the tablet?
    • Like Like x 2
  3. rdavage
    rdavage Member
    NULL
    This is link with written instructions and video for version 827 just follow them the same for 1014. If the above link does not have the burntool this one can used. The main thing is to remember to save and name uboot, zimage, system and userdata after you extract to your hard drive to replace the ones on burntool. Promise it is easy it took me a couple tries.
    www.Zenithink.us
  4. br_elwood
    br_elwood Member
    NULL
    I have a simpel question...:rolleyes:
    I own this Apad/Epad and flashed it to 1013, working great but how do I know what firmware I can use ? I see now 1014 and even 1020 is available, where does it depend on if you can use a particular firmware ?
    thanks in advance,
  5. hoben02
    hoben02 Senior Member
    usa
    epad zenithink zt-180
    update to the 1020 firmware. it corrected the following issues: now the android market is available after the upgraded and it took care of the issue of having to change your router setting if you were connecting over wifi with wep
  6. ali.g
    ali.g Member
    sheffield uk
    epad zt-180
    hi there
    need need help to (zImage_update_ce) for my epad zt-180 . please
  7. McBub.com
    McBub.com Senior Member
    Shenzhen, Guangdong, China
    Ainol NOVO 7 Paladin, NOVO 7 Elf, Samsung Galaxy SII, iPad 2
    Is this also fit for the 7 inch ZT 180 ?
actualizre tableta zt181
android update for zt180 free download
android zt 180 epad support
epad android software
epad zt 180 firmware
epad zt 180 firmware update
zenithink epad
zenithink epad 10-inch
zenithink epad firmware download
zenithink epad zt-180 firmware download
