Zenithink ZT-180/Infotmic AV-P8088 firmware ver 9 Reflash!
wroenaldinho
hi, i bought an ePAD listed as a Zt180 however after further research and software in the about on the actual tablet it appears to be a infotmic processor and not a zt180. The problem i am having is that when i turn my tablet on it lasts for 30 seconds and then freezes up. i would like to reflash the software first rather than sending the tablet back, however using a program called winhex i cannot make my 2gb sd card bootable following the instructions from the following site:-
Support section with drivers, firmware files, instructions, etc.
it appears everytime i clone my sd card it displays as 1.9gb instead of the 705mb required.
can anyone tell me what i need to do, as im stuck and have tried everything i can think of.
cheers
edit: fixed it now was just going a little bit wrong according to instructions, absolutely mint now!
CrazyFrog
Hi,
Do you suceed flashing it? If yes could you copy the data from the "about" box in the configuration options? I *think* I've the same tablet but it comes with firmware version 11 and I was unable to find this version anywhere.
cheers
uplade3
Super Moderator
751
62
Can you make a short tutorial and post it here about exactly what you did? It would help others immensely.
