zt-180 red blinking light and no charge
Discussion in 'Zenithink ZT180 10 Generation 1' started by juched, Aug 16, 2010.
  1. juched
    juched Member
    Canada
    My ZT 180 arrived, it booted (with very low battery). Touch screen, and all worked, even connected to my wifi. Powered off to charge, came back and all lights seemed off. Now I notice that the red light blinks slowly and the adaptor makes a clicking noise, but it doesn't charge and hence won't boot.
    Is it the charger or the tablet do you think? What is the power spec on the charger? Mine says 9V 2000ma.
    Thanks.
  2. jtbnet
    jtbnet Member
    NULL
    My Guess would be the adapter which is at least the easiest to try replacing... the charger is 9volts 2amps and I just checked mine plugged into wall but unplugged from tablet with a meter and it seems to be a regulated 9.35volts...
  3. juched
    juched Member
    Canada
  4. xaueious
    Canada
    Generic devices ship with crappy chargers. From reading about this device though, that's just the start of your worries...
  5. juched
    juched Member
    Canada
    Ya, I know it was a risk. I have heard good and bad on this device. Got it from Eternal on Aliexpress, and they were good with my rockchip.
  6. juched
    juched Member
    Canada
    Bought the universal adapter and it is running and charging again.
  7. xaueious
    Canada
    Well that's good news.
blinking red battery in android tablet
my android nextbook charge light just blinks
my nextboik is blinking red when i charge
nextbook flashing red light
nextbook is flashing red and orange
nextbook red light blinking
nextbook red light flashing
nextbook tablet blinking red light
nextbook tablet light is blinking when charging and wont power up
what to do when red light is blinking on nextbook
