Battery Question
Discussion in 'iPhone Help' started by Jossef, Jul 2, 2010.
  1. Jossef
    Jossef New Member
    I notice that when I am charging my iPhone 4 that I can feel heat on the bottom of the phone. I am not saying that it is hot it is just warm to the touch. Is this normal or is this a problem?
  2. iPadOne
    iPadOne New Member
    Asia
    Hi i didn’t notice that, but i have notice when i upgrade my 3Gs to iOs4 he become really hot …
    i think that really depend on temper he take but if that continue i guess you should go and exchange it
  3. Stabicus
    Stabicus New Member
    I would monitor it closely, not leave it plugged in over night (In case of fire) or until you ensure that its not anything major. Using a powerstrip or something to that effect can also help.
  4. DannyBoy
    DannyBoy New Member
    Lubbock, TX
    My 3GS was always a "warm" charger.... I don't think it's anything to worry about unless it's so hot to the touch you can't hold it.
  5. Jossef
    Jossef New Member
    Mine in no way gets hot. Just a little warm. I called Apple and was told that was okay.
  6. Gregoris
    Gregoris Administrator Staff Member
    United Kingdom
    i noticed that also, it does get pretty hot
  7. Jbj4iphone
    Jbj4iphone New Member
    Mine seems to stay pretty cool no matter what I'm doing.
  8. DannyBoy
    DannyBoy New Member
    Lubbock, TX
    Its funny I have had 3 different 3GS phones and some ran a bit warm when charging or playing games.....and some stayed fairly cool. I guess it varies from phone to phone. Also how much your using it and how far you run it down. I find the battery gets warmer when I get below %20 but any low battery get warm when almost out....so its more of a normal battery cycle vs a "HOT" phone.
  9. SJ-CALI
    SJ-CALI New Member
    San Jose Cali
    Mine gets warm, but nothing I'm worried about...
  10. uprising95
    uprising95 New Member
    uk
    yeah i would say its normal
    mine was the same
    fell asleep and woke up 3 hour later and the phone was cold
    so it must switch of charging rather than overcharge
