[SOLVED] WiFi Slowly Losing Connection
PSo
Jul 10, 2017
Hello, i have Prestigio PMP5570c duo and recently i ran into some problems. First i needed to replace a battery. I replaced a battery and tablet worked fine excpet i have one problem. Problem is when im not using internet its showing me full signal, but as soon as i open Chrome or Youtube or anything that requires internet my connection slowly drops to none. I would appreciate anything that could fix my problem.
Factory reset helps you? Or you could try to open of your tablet and see if all of the cables are on the right place.
Well first of all thanks for replying. I already opened it up several times and replaced the battery myself. I checked all wires connected to little antenna and it's all good until i close the tablet cover. I also did factory reset but it doesn't help.
I fixed it finally... I found my tablet's firmware and installed it. It all works now.
