7'' MID TABLET ANDROID 1.6 wm8505 wmt 2.1.2_105 NEED HELP
Discussion in 'Gome Flytouch Problems' started by tripsy, Feb 9, 2011.
  1. tripsy
    tripsy Member
    HI to all,
    i need help to know what ****ing tablet i have.
    I try to explain what i have on hands, because i powered on 1 times and after i try the update but no one work.
    Is a 7 inchs, android 1.6 is 128 MB, processor wm8505 and rom wmt2.1.2_105, this is what i remember.
    Have a green led when turned on and red led when charged.
    Vibrate at the start up.
    I post some photo, please help me, now the tablet don't work, what fw i need to use????
    I tell u i use 30 fw.
    The much error i get is:
    --> Erase File-System partition Fail! Exit!
    maybe the kernel don't support this NAND Flash.
    or with some Roms the flash work good but when i reboot the tablet he stuck on LOADING... after the android logo.
    • Like Like x 2
  2. tripsy
    tripsy Member
    • Like Like x 2
  3. kssark
    kssark Member
    Mid Tablet PC
    Hi all, first of all introduce myself, I'm new to the forum and appreciate all the support provided to users by the members. I hope to also provide assistance to those in need.
    That said, I know that I have in the same situation as tripsy, but with some different specifications, in theory my tablet PC MID is:
    - 256MB
    - rom WMT2.1_105
    - generic model
    - compilation 2.6.29_00236-g4f8dbbb-dirty "
    - + wm8505 chip
    I bought it in gogoorder.com
    It happens like tripsy has the green light and red when charging. Vibrates when turned on.
    Currently he is dead.
    PS: sorry for English, use google translator.
    PDD: insert some pictures of the outside (outside is like that of tripsy) and inside (I opened it and saw that it was WM8505 +), but not inserting into the post.
  4. RomanticEvil
    RomanticEvil Member
    Tilburg, the Netherlands
    Gome FlyTouch / SmartQ7 / HTC X7500 / M006 / CVUK-PC06-2GEN / WMT2.1
    Tripsy, you have the EXACT same box as I have here! I also had A LOT of problems flashing this device but.... FlyTouch (MID) (CVUK-PC06-2GEN) (WMT2.1.2_105) did the trick for me. Almost almost 100% certain this is the right ROM for you. Try it and let me know how it went.
  5. tripsy
    tripsy Member
  6. pacc
    pacc Member
    italy
    also I have the same problem please who has resolved mails the solution.
  7. RomanticEvil
    RomanticEvil Member
    I'm afraid you did something wrong if that firmware fails, give it another go and format your SD before booting the tablet, I don't think you have another model, it's exactly the same, good luck
  8. x01
    x01 Member
    Hi,
    this is my first post, sorry if i break some presentation rules btw i've the same pad here and all works perfectly with 88_wmt2.1.1_2.1.2_20110213-HcH.
    my mid was start after 10 minutes, i was thinking the same as you the first time.
    • Like Like x 2
  9. RomanticEvil
    RomanticEvil Member
    Hello x01, I'm glad my rom works fine for your device! Must say the ROM needs some tweaking but I'm working on the next version, if all goes well this weekend it will be uploaded!
  10. tripsy
    tripsy Member
    hi romanticevil, i have try the rom and the newst one but same error
    erase file-systen partition fail!exit!
    • Like Like x 2
  11. tripsy
    tripsy Member
  12. kssark
    kssark Member
    Mid Tablet PC
    Hi, I'm with my tablet died, with WMT2.1.2_105_M_V1.0_script alone with that when turned on vibrate and go ga android icon.
    I'm desperate, I do not ever regain the tablet.
    There is someone who can help me??
    The tablet that I have has the same box of photos, and the same housing.
    In theory it is 256MB, the factory was WMT2.1_105 rom, generic model, compilation 2.6.29_00236-g4f8dbbb-dirty, + wm8505 chip.
    Thank you all for your help.
  13. dukeuy
    dukeuy Member
    Hello
    I downloaded and installed the firmware from the link UBEROID
    My APAD has the following characteristics:
    Memory - 256MB DDR2 800Mhz.
    CPU - VIA 600MHz MW8505.
    Display - 7 "
    The installation completes OK, but then I APAD didn’t boots.
    Try to install another firmware and do not let me.
    Can someone give me any clues ?
    Thank you very much in advance.
    Regards.
  14. eliel10
    eliel10 Member
    hay all
    i have the same problems.
    but my ped came up and work but the wifi dont work and the tuchpad dont work
    do you find how to fix it?
  15. Naing12656
    Naing12656 Member
    Yangoon
    flytop
    Please send me firmware WMT 2.1.2-105 with instruction for intallation to my ROM. Because my one is missing firmware and replace with new one so that i need urgently , pls help
android wm8505 without nand
descargar wmt-commres
firmware mid wm8505 rom downloads
mid tablet
mobee wm8505
software android wmt
via wmt8505
wm8505 tablet firmware no right one
wmt commres
wmt-commres
