Charger Problem :(
Discussion in 'Asus TF101/SL101 Forum' started by terramishu, Jan 29, 2012.
  1. terramishu
    terramishu Member
    [ background story ]
    I avoided buying the Prime since I've heard a lot of complaints about WiFi connectivity issues.
    However it seems like I still couldn't avoid another problem: charging issues. Twice, and I've had the Transformer for 3 weeks now. Sigh!
    My tablet seems to work fine and the usb cable as well (works when plugged into the PC).
    I did notice that the "head" of the usb cable looked a bit crooked when plugged in my tablet... and a bit flimsy? It wobbles around if pushed gently.
    Also, I tried pushing/spreading the the pin connectors inside the Adaptor and it worked once (yay).
    Unfortunately... the charger isn't working again. Spreading the pins didn't work this time. I now have my Adaptor in my freezer and I hope that'll fix it.
    TL;DR
    Charger isn't working.
    Looking for...
    • Your experiences with this issue
    • Fixing success stories
    • How many new chargers have you bought within x period of time.
    • Online or stores where you have gotten a new charger
    • Alternative adaptor; not from Asus
    Thanks for reading!
    -- Update --
    Freezing the adaptor worked.
    Geez... Wonder when my adaptor will break down again.
    If any of you are looking for charger alternatives or DIYs, http://forum.xda-developers.com/showthread.php?t=1087321.
fix android tablet charger
how do you fix digital2 tablet charging problems
how to fix a android tablet charger
how to fix android tablet charger
how to fix charger to work on android
how to fix twisted tablet chargers
how to fix your tablet charger
how to repair tablet chargers
how to repair tablet charging
problem with verizon tablet chargers
