DVD Catalyst Guide Collection (DVD, Video, Bluray)
Discussion in 'Android Tablet Video' started by dvdcatalyst, Jul 4, 2011.
  1. dvdcatalyst
    dvdcatalyst Guest
    Top Poster Of Month
    I posted a couple of guides on my website that can be used to get movies on Honeycomb Tablets (Xoom, Transformer, Tab2, Thrive, Acer etc). They cover the most asked questions I receive on forums as well as by email, so I figured it would be easier to collect them into a single post.
    Sample videos. If you visit this link on your Honeycomb Tablet you can see what it is capable of:
    Index of /xoom/fullscreen
    For Getting Started Guides, have a look here:
    Step By Step | DVD Catalyst 4, the ultimate app for movies & tv on the go
    For a guide on how to use DVD Catalyst with Bluray:
    DVD Catalyst 4 v4.0.3 Beta, aka Bluray Catalyst | DVD Catalyst 4, the ultimate app for movies & tv on the go
    How to get your movies to play in full-screen:
    How to make all your movies full-screen for Xoom, iPad2, iPhone4, Atrix and more | DVD Catalyst 4, the ultimate app for movies & tv on the go
    Streaming. A while ago, I created a (free) streaming server application that you can use to stream your existing mp4 video collection to pretty much any android device:
    How to stream movies to your phone for free | DVD Catalyst 4, the ultimate app for movies & tv on the go
  2. Jakesaturn
    Jakesaturn Member
    Atlanta, GA
    Toshiba Thrive
    Awesome work, I will be dowloading this shortlt to try out!
    • Like Like x 1
  3. mlbarber
    mlbarber Member
    illinois
    samsung galaxy tab 10.1
    has anybody used this program? if so, how does it work?
  4. dvdcatalyst
    dvdcatalyst Guest
    Top Poster Of Month
  5. mlbarber
    mlbarber Member
    illinois
    that link didn show me anything. i have used cucusoft converter in the past but when i put the movies on my tablet, I could hardly hear them. I had to convert them at such a low rate that i think it affected the sound quality.
  6. dvdcatalyst
    dvdcatalyst Guest
    Top Poster Of Month
    The link was a basic search for "dvd catalyst" on these forums, and should have showed you the posts from other people who were using it.
    I noticed you posted in the Galaxy Tab 10.1 forum section, so assuming you have one, visit this link on your tab to get an idea of the video and audio quality possible:
    Just tap on one of the MP4 links to have the video play while downloading (stream)
    The files there are created with DVD Catalyst 4, and should play perfectly on your tab using the build-in video player.
  7. mlbarber
    mlbarber Member
    illinois
    yes i have a galaxy 10.1. very impressed with the video and audio quality. what is the typical size of a full length movie? The other software I was using wouldnt let me convert more than .97GB without breaking up the movie into parts.
  8. dvdcatalyst
    dvdcatalyst Guest
    Top Poster Of Month
    It depends on the kind of quality you want. The files there were encoded using the Xoom HQ2 profile, which ends up around 2.5GB for a movie. If you convert DVDs, you can just select the Xoom profile, and you are looking at about 1.5-1.8GB for a 2 hour movie.
    This should give you a basic idea. The article doesn't fully apply to tablets, but it shows off different quality settings, and how you can get smaller files while still keeping the files watchable.
    DVD Catalyst 4 – Quality difference between different profiles | DVD Catalyst 4, the ultimate app for movies & tv on the go
    After scanning the DVD (before you start the conversion) DVD Catalyst gives you an estimate on how large the file is going to be. If you would like to trade a bit of quality in for smaller files, just tap on "Modify" in the program, and lower the video quality setting a bit.
    For fast action movies (explosions and such), I would recommend leaving it as is, but for slower (comedy/romance) movies, you could go about 20% lower and still have great looking video files.
  9. mlbarber
    mlbarber Member
    illinois
    thanks for the quick responses. i am going to try and download the trial version tomorrow.
  10. dvdcatalyst
    dvdcatalyst Guest
    Top Poster Of Month
    You are very welcome,
    To get you started, have a look here:
    How to : Convert DVDs and Video files for the Samsung Galaxy Tab 10.1 | DVD Catalyst 4, the ultimate app for movies & tv on the go
    Just follow the steps described, and you are good to go.
    The guide is long, but its loaded with screenshots for everything. Once you get into it you will notice the process is actually just a few clicks.
  11. mlbarber
    mlbarber Member
    illinois
    I downloaded the trial version today. it worked great. i just purchased the full version. i will let everyone know how well it works. the audio is so much better than the current software that i use.
    • Like Like x 1
  12. ShinP
    ShinP Member
    Boston, MA
    Toshiba Thrive
    I have had the full version for a couples of months and it works pretty well. The full version has a ton of settings which I haven't really played with.
    Sent from my AT100 using Android Tablet Forum
