HDMi audio setting
Discussion in 'Asus TF300 Forum' started by prince81, Jun 11, 2012.
  1. prince81
    prince81 Member
    tf300
    Hi,
    When I connect my tf300 to the TV through micro HDMi port, I do not receive any audio.
    The video is transmitted fine.
    Does anyone know if I need to change any setting on the tablet?
    Tried couple of cables to be sure that the cable is working fine.
  2. leeshor
    leeshor Senior Member
    Norcross, GA
    Samsung Galaxy Tab S 10.5
    Welcome to the forum
    Have you tried any alternative players, like MX Video or Mobo Player. You didn't say what you were using so I assume it's the default and you don't get much from the default player.
    • Like Like x 2
  3. prince81
    prince81 Member
    tf300
    Thanks for your reply.
    I am using MX player to play the video content.
    I will try default player as well.
  4. leeshor
    Norcross, GA
    If have tried MX, try BS Player as well. One of them should work and I'm surprised that MX didn't.
    • Like Like x 2
  5. prince81
    prince81 Member
    tf300
    Sure. will give it a try.
  6. wallydog
    wallydog Member
    cincinnati
    asus tf300
    I had the same problem , I found that with my TV the TV has to be on and the hdmi connected then turn on the tf300 and the sound worked . I think its about the way the TV handshakes .
    • Like Like x 4
  7. prince81
    prince81 Member
    tf300
    I will try this tonight.
    Thanks.
  8. colleenaz
    colleenaz Member
    USA
    Asus Transformer TF300
    That happened to me also. I accidently had the speaker turned off so I turned it up with the control on the upper left hand side. Hope this helps.
android disable hdmi audio
android hdmi audio disable
android hdmi audio settings
android hdmi disable sound
asus tablet hdmi audio
asus transformer hdmi no sound
audio config android hdmi
bypass hdmi audio tablet
bypass tablets sound via hdmi
disable android sound in hdmi
disable audio hdmi android
disable hdmi audio android
hdmi android audio output settings
hdmi audio settings android
hdmi no sound android tablet
hdmi setting on asus tablet
hdmi sound disabled android
hdmi sound output android tablet
how off audio hdmi on android
turn off audio hdmi android
