Hello and Help!!
Discussion in 'Acer Iconia Tab A500 Forum' started by debbie74, Oct 10, 2011.
  1. debbie74
    debbie74 Member
    UK
    Icona tab a500
    Back in August i went into PC world to buy a Ipad... but after speaking to the guys i was told the Acer Iconia A500 tab was the better option.... how wrong! we are now in October i am still struggling to get movies onto the tab! ive downloaded rebooted and still it wont do it? im just about ready to bin the thing. Even after numerous downloads of apps they wont show or i cant find them.....wish id have stuck with apple :mad:
    im giving this forum and the help of you guys one last chance before i sell this waste of space item!!
  2. Spider
    Chicago, IL
    Hi Debbie, welcome to the forum. Sorry to hear you're having problems with your A500. I'm going to move your post to the Acer Iconia Tab A500 Forum section of the forum. When they realize the honor of their favorite tablet is at stake, I'm sure someone over there will help you out.
  3. frnkws
    frnkws Member
    PA USA
    Acer Iconia A500
    Well with a little searching you will find a number of threads dealing with movies, where they are on tablet and how toget them to play.
    there are threads on which apps are best.
    All the information you need is already here somewhere.
  4. Tom T
    Tom T Senior Member
    Washington State
    Hauwei S7
    One thing that will probably help, useing a file explorer {I suggest ES File Explorer, free from the market} just navigate to the movie you want to watch and click on it, it will give you a choice of the apps you have installed that can view the movie file, choose one and you should be good to go.
  5. Douvie
    Douvie Senior Member
    Kyneton, Australia
    Debbie74,
    As suggested your need to go to the android market and dowload ES FILE EXPERT which is a browser. After that Another app that I suggest is to download MX PLAYER and the MXPLAYER CODEC ARM7V... this will allow you to watch HD movies in 1080p on your A500.
    However certain formsts like the windows .wmv and .wma I believe can't be played.
    The A500 is much better than the iPAD2.
    :eek:
  6. ObsidianBlk
    ObsidianBlk Member
    Connecticut, USA
    Acer Iconia a500
    And if you're attempting to play movies you've purchased though iTunes or amazon... they simply will not play. ITunes specificly uses a digital rights management (DRM) scheme that prevents all but iTunes and I* devices from playing them.
  7. sopranosv
    sopranosv Member
    El Salvador
    Well I think that knowing which format of movies are you attempting to play will help in order to provide the best option to you. In my case, I have a bunch of MP4 with subtitles for the kids so I use mVideo Player and it is great; it also allows you to select the size and position of the subtitles.
    I do have an iPad and the Acer Iconia A500 and I just hated having to delete one or two movies in order for new ones to fit. With the Iconia I only copy and paste into my external SD card and that's it. I carry around a 8GB SD card with some movies for my 7 years old princess and a 16GB SD card with some Two and a Half Men episodes for my airport/plane time. For sure, not being obligated to go back to iTunes every time I want to copy a movie or new music is just amazing when you have to spend half of your life traveling.
  8. Icebike
    Icebike Senior Member
    Typical drive-by flame post extolling the virtue of the iPad and then disappear.
    With exactly one post to "her" name "she" is off the grid and doesn't respond to anyone.
    The intent was never to get help. The intent was to troll the forum with an an iPad advertisement.
    • Like Like x 2
  9. Desso
    Desso Member
    North Carolina
    Acer Iconia A500 16gig
    some people are better off with apple.
    the others are better.
  10. Desso
    Desso Member
    North Carolina
    and using a girl's name gets all the technogeeknerds jumping.
  11. debbie74
    debbie74 Member
    UK
    Icona tab a500
    Excuse me I also work full time and don't always get online! I've managed to get four movies onto a external SD card but trying to save them on the device?
  12. debbie74
    debbie74 Member
    UK
    Icona tab a500
    Thank you I am going to try this app now, how do I save them to the device memory? I have four on my SD card?
  13. debbie74
    debbie74 Member
    UK
    Icona tab a500
    Yes well I am a woman thanks! Like I said I work! And this Acer isn't even 3G!
  14. tumpy
    tumpy Senior Member
    NYC
    Elocity A7
    debbie74, a simple way to get movie on the tablet, when tablet is connected to the computer it will show Internal storage if you have an sd card inserted it will show as sd card, you can copy and paste your movies in internal movies folder.. as for 3G i think you need the A501...
  15. Spider
    Chicago, IL
    There's no need to put the movies on your device, in fact most people try to keep as much as possible off their device and on SD cards. Use the app to locate the movies and tap on them. They should play just fine if your SD card is a class 4 or higher and the movies are in a format supported by your device.
