Hi I have a new Samsung Tab3, and the tablet disconnects from wifi quite often, when i have not been using it for a while. How could I fix it? Thank you!
Welcome to the forum There is a possibility that you have a slight issue with your router configuration, (you can find out more about WiFi issues from the link in my signature). But there is also a setting that sets the WiFi to stay connected full time. That would consime more battery unless you did one more thing. There is an app called Auto Airplane Mode, (by DON) that will cut the WiFi when sleeping then auto connect when the tab wakes up.
